Pixel Spy 1.3.1
Pixel Spy 1.3.1
Download: http://archive.info-mac.org/gst/grf/pixel-spy-131.hqx
Pixel Spy is a simple utility which allows you to determine the magnitude of
the various color components which make up a color on the screen.
Specifically, you can select a pixel from the screen, and Pixel Spy will tell
you the RGB, HSV, CMY, indexed and hex code values for the color of that
pixel. You may also modify these displayed codes to manually change the
current color and use Pixel Spy to match the current color to one in a color
lookup table.
This update adds Photoshop CLUT support and improved color detection accuracy,
among other minor additions and fixes.
