PixPlayer Mac 1.0
PixPlayer Mac 1.0
Download: http://archive.info-mac.org/gst/grf/pix-player-10.hqx
PixPlayer Mac 1.0
PixPlayer Mac is a picture viewer. PixPlayer Mac allows you to combine
still pictures and movie files in the same slide show. PixPlayer Mac
allows you to save your slide shows for future playback. PixPlayer Mac
can have several players running at the same time. PixPlayer's Quick
Access buttons make loading favorite folders a snap. PixPlayer also
proved commands for moving and deleting files in bulk or one at
a time.
PixPlayer Mac requires:
MacOS 8.0 or later
10Mb RAM
The user manual and download are located on the
TechSono Engineering, Inc support site
http://www.techsonosupport.com
You can also select Online Support from the
PixPlayer Help menu.
if you have suggestions and/or comments,
please send to to:
