Pictodexer 1.0
Pictodexer 1.0
Download: http://archive.info-mac.org/gst/grf/pictodexer-10.hqx
Pictodexer 1.0 - is a no-frills image indexing utility which creates "thumbnail
gallery" pictures for folders of image files. Pictodex indexes are modified
Macintosh PICT files which means that they can be viewed with any app that can
view PICTs. Pictodex files also contain references (relative paths) to the
original files so that when viewed with the Pictodex Viewer, you can click on the
thumbnails to open the original images in another app for editing or viewing. The
Pictodex Viewer can also be used as a simple image viewer since it can display
any image type that QuickTime can recognize. Requirements - Pictodexer requires
Apple's QuickTime and MacOS 8.0 or higher.
