Download: http://archive.info-mac.org/gst/textation-111.hqx
Textation 1.1.1
(c) Copyright 2002 Feelorium Limited, All Rights Reserved.
[email protected]
http://www.feelorium.com
Textation is an easy to use QuickTime text track editor. Simply point,
click and type the text needed to display, without the need to manipulate
text descriptors manually and type time codes one by one. Textation can
also check the validity of time codes while you input data.
Textation also supports creations of Chapter Tracks and HREF Tracks, as
well as subtitle/caption tracks. It is easy to create these types of
tracks in seconds using Textation.
You can also preview the resulting movie on the same project window by
just clicking a switch.
What's New
- This version correctly sets the start time of the exported text track if
the first sample time of the track is greater than zero.
System Requirements
- Mac OS X 10.1
FEELORIUM
[email protected]
