TcTC 1.0, Timecode Converter and Calculator
Download: http://archive.info-mac.org/gst/tctc-10.hqx
TcTC is a timecode converter and calculator application.
Timecodes, edgecodes and framecounts can be converted into several
other formats simultaneously. The basic math operations can be
performed on these timecodes.
The supported TC formats are PAL, NTSC Drop, NTSC Non-Drop, HD/Film
24p, 35mm, 16mm20, 16mm40, framecount, as well as TC and EC formats
with freely selectable framerates (currently between 1 and 100
fps/fpe).
An offset management system deals with situations in which timecodes
have changed due to transfers. If the same frame that originated on a
piece of film and is identified there by an edgecode is transferred
to, say, two different tapes and ends up there having two entirely
unrelated timecodes, TcTC offers a method of establishing a relation
between these different, essentially arbitrary edgecodes and
timecodes and thus allows you to keep track of the footage in the
various places.
TcTC requires a Macintosh with a PPC processor and MacOS 8.5 or higher.
