MPegger Drop Decoder 2.0.1
Download: http://archive.info-mac.org/gst/mpegger ... er-201.hqx
What is MPegger Drop Decoder? Want to burn those MP3s you nabbed off of
the internet onto a CD? You'll first need to decode them - that's where
MPegger Drop Decoder comes in. Very simply, it will make your MP3s into
files that you can burn onto a CD, and listen to in any conventional CD
player. Technically speaking, this software will automatically convert
any MPEG-1 or MPEG-2 LSF layer 1, layer 2 or layer 3 audio file into an
AIFF file, Sound Designer II file, or PeeCee Wave file.
It should correctly recognize and decode all ISO-standard mpeg audio
files, and is for PowerPC MacOS machines only.
The MPegger Drop Decoder is a fully compliant ISO/IEC 11172-3 Layer 1,
Layer 2, and Layer 3 audio decoder, and passes all compliance bitstream
testing in accordance with the specifications outlined in ISO/IEC
11172-4.
