K25KComp.sea.hqx
K25KComp.sea.hqx
Download: http://archive.info-mac.org/gst/k25kcomp.hqx
The Kurzweil Companion is your remote interface to the best keyboards
in existence, the Kurzweil K2500/K2600!
The Companion allows you to control your K2500/K2600 from your
Macintosh. This both saves wear and tear on the K2500/K2600 buttons)
and it allows you to work more efficiently.
Take the simplest task on your Kurzweil. You've just created a new
program, or layed down the first track in a sequence. The K2500/K2600
wants a name for this new object, and you sit there for 5 minutes
spinning the data wheel or pecking at the keypad to enter "Rad Piano"
or "Techno Song".
Forget it! Now just reach over to your Mac keyboard and type on a
normal keyboard!
And that's just the start. The Companion allows you to see your
K2500/K2600 screen remotely, allows you to enter numeric data for
things like frequencies, select programs from a complete, searchable
list instead of 8 crowded lines, export the list of objects in your
machine, and more and more!
The Companion also adds some additional MIDI controllers, a ribbon,
an X-Y touchpad, and so on.
Brought to you by C.K. Haun and Ravenware Software. The Kurzweil
Companion is free.
System requirements: Any Macntosh running System 7.5 or later (68K or
PowerPC). The Companion works with the OMS MIDI software package
(freely available from OpCode) or the latest FreeMIDI in OMS
emulation mode from MOTU. A two-way MIDI connection between your Mac
and K2500/K2600.
