Trainspotters Puzzle 2.1; fitword crossword puzzles
Download: http://archive.info-mac.org/game/word/t ... zle-21.hqx
Trainspotters Puzzle makes fitword crossword puzzles from a chosen source of
words; for example a text file or computer generated 'license plates'. You can
now solve the fitwords puzzles on the screen. Registered users get access to
complete crossword solutions, and they can use the program as a tool for making
traditional crosswords. You can print out the puzzles in SimpleText. A fitword
puzzle is a type of crossword where you get all the solution words and it's your
task to fit the words into the grid. The program is 'fat'; it runs native on
PowerMacs and also on 68K Macs. It requires System 7 or later.
New in version 2.1: You can now save a wordlist as a text file by choosing 'Save
Wordlist' in the main dialog. Words in the crosswords can now consist of both
letters and numbers.
You can get more info and see examples of crosswords generated by Trainspotters
Puzzle at:
http://home.sol.no/merdem/trainsp.html
The attached file should replace
'/info-mac/game/word/trainspotters-puzzle-14b.hqx'.
Cheers, Tore M.
