submission
submission
Download: http://archive.info-mac.org/game/word/karma-manager.hqx
Karma Manager v 1.0 anagramming program
Once upon a time there was a program called ARS MAGNA by Michael Morton
which created anagrams. Alas, it didn't run on my system, so undaunted,
I decided to write my own. It has a reasonable (if sparse) Mac interface,
and it runs in the background under System 7.
Karma Manager is a program which takes a word or phrase and rearranges
the letters into other words or phrases. For example, if you take the
phrase "Anagram Maker" you can rearrange the letters to get "Karma Manager."
Karma Manager comes with a dictionary of words which it will use to create
anagrams, or you can supply your own dictionary or dictionaries. It will
also read the ARS MAGNA dictionaries so you can still use those if you have
them (and paid for them :-).
The output is dumped by default to a resizable window and it can optionally
capture the output in a text file.
Karma Manager is Shareware and costs $7.
Chuck Grissom
