Star Wars Racer Setup 1.0.3
Demos, tips, editors, and anything that goes with commercial entertainment software.
Download: http://archive.info-mac.org/game/com/st ... up-103.hqx
Star Wars Racer Setup 1.0.3 is a utility wich can be used to create a
setup file for Star Wars Pod Racer.
I created it because I think that editing a text file is a clumsy way to
setup a game.
Version history 1.0.3 I changed the way the file is found again because
the last version had a bug there, I now create a prefs file which is a
much better solution, I added the extra features of StarWars Racer 1.0.1
1.0.2
I changed the way I find the file, all you have to do now is set your
podracer folder, then the file is replaced, the original is trashed but
then again you can set everything that is in the file with my setup
program. Added a help button (and some help too) Put a version number in
the Setup dialog.
1.0.1
Added my email adress and website to the readme
1.0 There is one thing I could not do, find out where the file
Switches.txt, which it creates, is on your hard disk so instead I place
it directly at your startup disk.
You should copy the file to the data folder inside the copy of podracer
on you harddrive.
This is a freeware app.
happy Pod Racing.
regards,
Wim van Ommen
www.applescript.tmfweb.nl
