Sim Scenario Maker 1.0b
Demos, tips, editors, and anything that goes with commercial entertainment software.
Download: http://archive.info-mac.org/game/com/si ... er-10b.hqx
LEGAL:
Note: Once you have registered your copy it is not shareware, please do not
distribute it on any bbs's or public ftp sites without my permission inless
you unregister it by going to the Unregister menu in the Apple Menu.If you
want to distribute this program on a CDROM or Magnetic Media I grant you permission
as long as I recieve one copy of the CDROM or Magnetic Media. I still reserve all
rights to my software.
DESCRIPTION:
This program simply copies the required resources into your SC2K city file and
allows you to edit the scenario settings.
You can drag and drop a file onto the Sim Scenario Maker and edit it, or drag
and drop while holding down option to set the city to the defaults
You can do multiple files at once, by hitting the Cancel All Button
you will stop processing of the remaining documents.
By holding down option when going to the open menu you will reset the scenario
to the default settings
You can change the scenario picture by clicking on the picture button.
The file you select for the new picture must have a pict resource id 0.
The picture must be 65x65 pixels in dimension.
I am not responsible for anything unforseen problems this program may cause.
After editing your city scenario settings the file must be put in the same
directory as SC2K for it to notice it.
Note: I have no idea what build item One and Two are!
For further help try balloon help.
PLEA:
If you like this program and have not registered it please send me $5(US) along with
your name, program, and program version and I will send you a registration code.
Please write the name of the program on the back of the envelope for faster service.
Robin Emig
4010 Jefferson St.
Napa, CA 94558
Also, any future versions I release of the Sim Scenario Maker you will recieve
for free (sorry email only).
If you can't send a check for US$ or cash US$, send the approximate equivalent
in your country's currency if you can, else email me.
BUGS:
If you would like to report a bug or have any comments or questions please
send snail to above address or email at [email protected]
******If you want me to respond at all to your bug report you MUST do the following*******
include in the title of your message Sim Scenario Maker
include where you got the program
include what computer/ system version/ Sim City version you're using
Sorry but I recieved way to many messages that just said "It doesn't work"
What am I supposed to do with that?
VERSION HISTORY:
1.0 First release
