LinksToMac 2.03
Demos, tips, editors, and anything that goes with commercial entertainment software.
LinksToMac 2.03
Download: http://archive.info-mac.org/game/com/li ... ac-203.hqx
LinksToMac reads Links 386 DOS golf course disks and converts them to
Links Pro for Macintosh courses. You simply insert the DOS disks into
your Mac and LinksToMac does all the work for you. It will automatically
find the 386 courses on DOS disks and ignore the older Links courses.
Registered users can also convert courses from CDRom and four-disk floppy sets.
What You Need:
Any Macintosh.
2 Megs of free memory or 2.7 megs if converting from CDRom.
2 to 3.5 Megs of free disk space for each course you want to install.
System 6.05 or later.
Macintosh PC Exchange or similar INIT to enable your Mac to read DOS disks.
Super Drive
Links course disks containing a Links 386 course.
