LemmingsCheat 2.0 - edit Lemmings Levels
Demos, tips, editors, and anything that goes with commercial entertainment software.
Download: http://archive.info-mac.org/game/com/le ... eat-20.hqx
Attached is a binhexed, stuffed version of a major update of LemmingsCheat
(new version 2.0, FAT). I fixed a major bug changed the Help-text and
compiled it as a FAT binary.
Excerpt from Readme file:
___________________________
LemmingsCheat lets you edit the Levels file of Lemmings. This way you can
give yourself more time, climbers, diggers, etc., lower the rate at which
those beasts come or lower the goal (the nr. you gotta save).
When you start LemmingsCheat you'll have to locate and open the
"Levels" file. Always make a copy of the original Levels file first!
You can open a level by typing in (part of) its name. This is
case-sensitive. Just change any of the parameters using the usual Macintosh
editing tools. Select the "Save" button to save the changes or the "Don't
Save" button to discard the changes.
LemmingsCheat 2.0 is a "Fat Binary", running native on PowerMacs as well as
on 68k Macintoshes.
Check for the latest version and other nice things at
http://kartoserver.frw.ruu.nl/staff/bjk/bjk.html
Legal stuff
LemmingsCheat is ©1996 by B.J. Köbben. It's POSTWARE: You can use and
distribute it freely, if you send a postcard or an e-mail to B.J. Köbben,
PO Box 80115, 3508 TC Utrecht, The Netherlands, [email protected]
Barend Kobben
