[*] Leyte Rescue 1.01
Demos, tips, editors, and anything that goes with commercial entertainment software.
Download: http://archive.info-mac.org/game/com/he ... rescue.hqx
How embarassing - a minor bug crept into the version of Leyte Rescue that
I released yesterday (Friday) at the last minute which may prevent it from
recognising the Hellcats Preferences file. Here is a minor update which
fixes the (non-fatal) problem.
LEYTE RESCUE 1.01
This little utility will recover non-active pilots in Hellcats: Missions
at Leyte Gulf. It restores pilots to "Active" status but does not change
any of their other attributes (ie: points, rank, kills, etc are remembered
from their former life).
It's been tested on a Mac IIfx running System 7.0.1 - I make no
guarantees that it will work with your system, so you should
probably take suitable precautions (i.e. back up first) in case
anything goes wrong.
To recover your pilots, launch Leyte Rescue, when the SF dialog appears
up just select the Hellcats Preferences file in your Preferences Folder
and then wait a few seconds. Launch Leyte Gulf and you should see your
resurrected pilots on the roster.
Since this is a very small application (2k) I've attached it below in
BINHEX 4 format.
This application may be freely distributed.
Good luck,
//Paul ([email protected])
