Super Mac Freecell 1.5
From solitaire to bridge. Any game that is played with cards.
Download: http://archive.info-mac.org/game/crd/su ... ell-15.hqx
Super Mac Freecell is a super addictive solitaire card game. What makes
Super Mac Freecell more interesting than most solitaire card games is
that the possibilities to win are only limited by talent. Nearly every
game (approximately 99.99 %) of Super Mac Freecell can be won. This
doesn't mean it is simple. Far from it, there is room for almost
limitless improvement. This makes Super Mac Freecell much more
interesting than solitaire variations like Klondike, where luck is a
large factor in the game.
Super Mac Freecell is US$15 shareware. It is available from the BrBo
Software web site and
all major Macintosh shareware ftp sites. Version 1.5 is a free upgrade
to registered users of any earlier version.
System Requirements: Any Apple Macintosh or other computer running MacOS
System 7.0 or later. Super Mac Freecell is distributed as a Fat Binary
that runs on 680x0 machines and PowerPC computers. Super Mac Freecell
is MacOS 8 compatible.
New Features in Super Mac Freecell 1.5
* Multi-Column Moves
Now Super Mac Freecell will handle large column moves with utmost ease by
using empty columns as temporary space to move cards into.
* Unlimited Undo
You can now undo your game all the way back to the start. And when you save
your game, the undo history is saved with the game.
* Add-on Deck Support
Have as many card faces as you want, just add them on. The format is easy to
build and anyone can make a card face.
* Game on hold
Allows you to quit the program with an unfinished game. When you start your
next session of Freecell you're given the option to finish the game from the last
session.
* Improved User Interface
Improved preferences dialog makes things easier, combined with other little fixes
make playing Super Mac Freecell even more enjoyable.
