Ladmo-060.hqx (A Bot for Bolo)
All manner of stuff for the multi-player (via network) tank battle.
Post by Info-Mac » June 26th, 1997, 9:00 am
Download: http://archive.info-mac.org/game/bolo/ladmo-060.hqx
Hi People,
Here is the second major release of Ladmo, a bot and limited borg for Bolo.
This is version 0.60.
While the version is at only 0.60, Ladmo is very competitive with Indy 2.02.
A brief list of changes from previous versions:
- Uses Pill views to update info.
- Black Lists bases it is unable to get to.
- Improved Attack Tank.
- Improved fixing pills at a distance.
- Clears walls around allied pills
- Fixed some refueling bugs.
- Automatic CPU sensing, which changes some internal options when CPU
power is deemed to be low.
- A new Attack Pill Method, called "Advanced Attack Pill", which makes
Ladmo the first bot to use a wall trick to take pills at times.
Still needs some work, but is definitely an improvement.
- Regular Attack Pill is now an improved version of the "New Attack
Pill" in earlier versions which uses just a regular shoot and run
method.
- Some borg fixes and changes.
- Some strategy changes.
- Various other improvements and additions.
Read the Revision History inside the Read Me for a complete listing of changes.
As always, comments and suggestions are welcome!
John
Ladmo Co-Programmer
