Sofware Submission
Sofware Submission
Post by Info-Mac » September 10th, 1999, 9:00 am
Download: http://archive.info-mac.org/app/btv.hqx
BTV is an application that allows you to easily view video from any video
digitising source, either full screen or in a window. It was originally
written for the IXTV (TurboTV) card however it has been successfully
tested with a number of video sources including various video input
cards, TV cards, built-in video hardware, and even USB video sources!
Features:
- Full-screen video with no menu bar
- Video in a window which can be dragged around the screen or resized
- Automatic monitor resolution switching to the resolution of your choice
(usually 640x480 or 800x600) and back to the original resolution on quit
- Multiple monitor support - play full screen video on one monitor while
you work on another
- Can capture a PICT file, either straight to the desktop with an
automatic file name or through the normal save dialog box
- Can record a movie to disk using custom video and sound settings
- Can black out other monitors on a multi-monitor system
- Can be set to disable background processes so no interference by
screensaver or powersaver
- Can adjust size of picture with arrow keys
- Can hide the mouse (this can be done automatically on startup)
- Can spin down hard disks for less noise (this can be done automatically
on startup)
- Saves all video and sound settings
System requirements:
Any PowerMac with video digitising hardware.
BTV uses 1400k of RAM, however if you never need to create PICT files you
can reduce this to about 400k.
Terms and conditions:
This application is Shareware which means if you use it you have to pay
the Shareware fee of US$15. Use the 'Register' program included with BTV
to pay your registration fee and obtain a personal registration code.
Alternatively, you may register online at
http://order.kagi.com/?UXT
Your code will unlock all future releases of BTV.
Please email any comment, suggestions or bug reports to
Legal Stuff:
BTV is copyright by Ben Bird. You may distribute BTV to others provided
that the package remains unchanged and that you do not charge for it.
This software is provided "as is" without express or implied warranty.
