TalkTime 1.0 - a talking scheduling application
Download: http://archive.info-mac.org/app/time/talk-time-10.hqx
TalkTime is a simple scheduling application for the Macintosh. It speaks
data about the events using Speech Manager. It can also display an alert if
you are going to be away from your computer at the time the event occurs.
This can help you if your forgetful, or if you just want the scare your
friends while they're near your computer. The unregistered version does not
allow you to make an alert appear (as described above) and will not let you
run the program for over 100 runs.
