Demon 1.0b1 - Doom level editor
Fast action games.
Download: http://archive.info-mac.org/game/arc/demon-10b1.hqx
MacDeu has been renamed "Demon". This file should replace the file
"macdeu-53b9v4.hqx".
Demon is a Doom level editor. This is a beta version, and is not entirely
stable. However, it does work. You can make levels for doom. There are
still a few interface inconsistentcies left, but for the most part it works
correctly.
You can always get the newest version of this program at my home page:
Improvements for Demon version 1.0b1:
*Added support for multiple REAL mac windows
*Added two new config options: windowWidth and windowHeight. They let you
set the default size for windows.
*Added scroll bars instead of auto scroll
*Added real menus. They all work besides the Objects menu.
*Fixed second sidedef dialog
*Lindef draw mode will start drawing on a vertex if there is one under the
cursor.
-James
