Download: http://archive.info-mac.org/game/arc/cl ... eks-12.hqx
Classic Daleks is a major update to one of the first Macintosh games.
This updated version was written by Ingemar Ragnemalm. It is freeware.
Changes from the original Daleks include color, a working high-score
list, and compatability with newer Macs.
In case you are not familiar with the original game, here is a brief
description.
You are a little man. You are being persued by daleks (robots). You must
fool them into colliding with eace other. You can teleport to other
parts of the screen to prevent being killed by the daleks, and you can
use your Sonic Screwdriver to kill any daleks in your vicinty. Beware,
however: although you have as many teleports as you want, you only get
one Sonic Screwdriver per level. If you are able to kill all the daleks
without using your Sonic Screwdriver, you can keep it for the next
level.
This game is quite addictive, I'm sure that once you start playing
it, it will be a permanent resident on your hard drive. I know it is on
mine.
Author E-Mail: mailto:[email protected]
Author Web Site: http://www.lysator.liu.se/~ingemar/
