Download: http://archive.info-mac.org/game/smallmines-251.hqx
SmallMines - There are mines hidden in a minefield. Clicking on a tile will
uncover its contents. It could be a mine, or a number. If it's a mine, then
you've blown up the mine in the minefiled (you've lost). A number tells you how
many mines surround the tile you just clicked on. If it's blank, then it means
that there are no surrounding mines. If you know where a mine is, then you can
hold down the control, command, or option key to plant a flag. If you planted a
flag in error, you can unplant the flag the same way you planted it. You win this
game by uncovering all the tiles that don't have mines underneath.
