Download: http://archive.info-mac.org/game/silvergol-20.hqx
Silvergol is a Carbon application that enormously facilitates your
formulation of complex systems of Totogol. Silvergol 2.0 lets you:
- create systems combining from 8 to 32 numbers
- constrain the columns by sum of numbers, simmetries, parallels,
interruptions, superinterruptions, lower and upper distances, tens,
finals, odd and even numbers, consecutivity, and constrained groups
- constrain systems with even more detailed criteria
- constrain the columns by championship
- recover unlimited number of wrong conditions
- reduce the constrained system in order to get second and third
category wins
- print the columns on paper and directly to Totogol forms
- import, export and manage the set of Totogol contests
- export the system to plain text
- customize the application to suit user's needs
- create systems by union, intesection, difference, domain or inversion
- check the system to see if you have won
Silvergol 2.0 has complete documentation in Italian language: please
contact us if you are interested in more information in English.
What's new:
- carbonized code
- abandon of 680x0 code
- native support of MacOS X through CarbonLib
- Navigation Services support
- newer Internet Config support available since MacOS 8.5
- faster kernel
- better compatibility with PowerToto 1.5/2.0
- automatic insertion in the applications lists of the Help Center
- some bugs fixed
