beermeister2.0.sit
beermeister2.0.sit
Download: http://archive.info-mac.org/app/beermeister-20.hqx
BeerMeister is the easy way to organize your homebrewing recipes. It is a
full-featured database designed explicitly for the needs of brewers with
import/export, printing, searching by any field, room for brewing notes,
and a recipe creation guide.
New to Version 2.0
+ Recipe creation guide: Use the guide to help you create recipes for a
variety of beer styles.
+ Save to file: In addition to exporting tab-delimeted recipes, you can
now save a recipe set as an editable text file for use in other documents
or programs.
+ Remembers last search/sort so the next time you start BeerMeister
you're right back where you left off.
+ Open multiple recipe books and copy/paste between them.
BeerMeister received a 4 cow rating (out of 5) from TUCOWS
There is an OS X (Carbon) version available at the BeerMeister home page
Ethan Rutter
MR Stuff Shareware
