EZCalendar v1.01 released!
Download: http://archive.info-mac.org/app/time/ez ... ar-101.hqx
Announcing the release of the Mac-only utility EZCalendar (from the
author of ScrapIt Pro, QuickScrap, EZNote, PopAddress and others)!
What is EZCalendar?
Have you ever needed to quickly jot down a note for a particular day on a
calendar and be able to easily find it later? Ever wanted to have an
alarm tell you a meeting is going to happen tomorrow or in an hour? Want
an instantly accessible, password protected daily journal/diary?
EZCalendar can do these things and more at the touch of a key (which will
instantly bring up a calendar) without having to leave the application
you are in!
EZCalendar will also show you the phases of the moon, allow you to set
yearly events (holidays, birthdays, etc.), appointments (and set alarms
to remind you if you wish) and have a note (up to 32k of text) for each
day of every year. Of course, you'll be able to search notes, yearly
events or appointments with ease!
Some uses for EZCalendar:
* set alarms for events in the future. EZCalendar will remind you
(minutes, hours or days) before the appointment is to happen!
* keep a daily electronic journal (password protected if you like)!
Bug fix in version 1.01:
* Fixed bug, was not searching yearly events
System Requirements.
Min. System..: 7 on up (Works great with OS8.x!)
Min. Hardware: Mac SE or better (Works great on PowerMacs!)
Shareware....: $20
Author.......: John V. Holder
email address: [email protected]
Home Page....: http://www.northcoast.com/~jvholder
