Download: http://archive.info-mac.org/app/baby-monitor-10.hqx
Baby monitor is a HyperCard stack designed to help you keep track of a
young infant's bodily functions - urination, defecation, and feeding.
Or, to keep things light, peeing, pooping and eating. It is designed to
run on an old Mac you keep next to the baby's things, so you can leave
it up all the time and use it easily as you go by. It is sized to fit a
640 by 480 screen.
Baby monitor is email-ware. If you use it, I'd love to hear from you.
Bug reports, suggestions and modifications are welcome. The only
requirements are that, if you change anything, you keep all
documentation with the new version, and send me a copy of the new
version. I understand that, during those long nights, it's not too
difficult to rock the baby in one arm and use the mouse with the other!
Baby monitor is provided as is, with no warranty. By using it you agree
that Jonathan Nigrine is not responsible for any damages caused by the
program or its use or misuse.
Requires HyperCard or HyperCard player 2.2. Might run on earlier
versions of HC, I don't know.
