Vocab version 1.8.1
Vocab version 1.8.1
Download: http://archive.info-mac.org/edu/lang/vocab-181.hqx
Learning vocabulary is one of the hardest aspects of a foreign language.
Easy and enjoyable to use, Vocab helps you quickly build the vocabulary you
want. It has won praise from language-learners and teachers the world over.
Vocab's intelligent test modes will help you learn words faster and more
easily. Statistical analysis and problem word tracking options help you
follow your progress. Vocab works with any language, and supports languages
with non-Roman scripts - including double-byte languages such as Japanese.
You can also record sounds to go with your words, and test yourself with
diverse options such as flashcard tests, slide shows and customizable test
modes designed to eliminate problem words.
With Vocab's free companion, Vocab Scheduler, vocabulary tests can be
scheduled to run automatically when due. Scheduler uses proven memory
techniques to help you learn, and maintain, vocabulary - for life!
Vocab 1.8.1 adds export features, removes limits on extra-long word lists
and improves memory management, alongside many other improvements and bug
fixes.
Vocab is shareware. For more information, visit http://www.cabsoft.com/
