V&N Webster TZ 1.2 - foreign language learning
Download: http://archive.info-mac.org/edu/lang/vn ... -tz-12.hqx
'Webster TZ' is a dictionary module for use with the 'Verbs & Nouns' and
'V&N Lookup' programs. You can download the latest versions of 'Verbs &
Nouns' and 'V&N Lookup' directly from the Info-Mac archives (the
Education/Language directory), or via links from this web site site:
'Webster TZ' contains the fifth part (letters T - Z and the "New Words"
supplement) of "The 1913 Webster Unabridged Dictionary". The other parts
are also available for downloading.
You can use the module for browsing, looking up words, many exercises and
word-games etc. You can add your own comments, definitions, phrases,
translations, sound or pictures if you wish. The module contains
translations to Spanish (which obviously do not belong to the original
Webster Dictionary) for part of entries. If you prefer the German or French
translations then you can use the enclosed files to automatically change
them.
The dictionary module itself is free, to use it you need the shareware
program 'Verbs & Nouns 2.6' or later (or 'V&N Lookup 1.4.7' or later) which
you can download from the same places as this module - the unregistered
versions of 'Verbs & Nouns' and 'V&N Lookup' have some limitations.
Jacek Iwanski.
