V&N Webster AB 1.2 - foreign language learning
Download: http://archive.info-mac.org/edu/lang/vn ... -ab-12.hqx
'Webster AB' is a dictionary module (simple-dictionary) for use with the
'Verbs & Nouns' and 'V&N Lookup' programs. You can download the latest
versions of 'Verbs & Nouns' and 'V&N Lookup' directly from the Info-Mac
archives (the Education/Language directory), or via links from this web
site site: .
'Webster AB' contains the first part (letters A, B and C) of "The 1913
Webster Unabridged Dictionary".
The dictionary module itself is free, to use it you need the shareware
program 'Verbs & Nouns 2.6' or later (or 'V&N Lookup 1.4.7' or later) which
you can download from the same places as this module - the unregistered
versions of 'Verbs & Nouns' and 'V&N Lookup' have some limitations.
Jacek Iwanski.
