Download: http://archive.info-mac.org/edu/lang/vn ... ict-10.hqx
'English Welsh Dictionary 1.0' is a dictionary module for use with the
'Verbs & Nouns' and 'V&N Lookup' programs. You can download the latest
versions of 'Verbs & Nouns' and 'V&N Lookup' directly from the Info-Mac
archives (the Education/Language directory), or via links from this web
site site: .
This dictionary contains more than 11000 English words (plus many
derivative forms and short phrases). It is based on the English Welsh
dictionary file Copyright 1994-1996 Mark H. Nodine. You can use the module
for browsing, looking up words, exercises, word-games etc. You can also add
your own words, translations, and comments.
The dictionary module itself is free, to use it you need the shareware
program 'Verbs & Nouns 2.6.2' or later (or 'V&N Lookup 1.4.7' or later)
which you can download from the same places as this module - the
unregistered versions of 'Verbs & Nouns' and 'V&N Lookup' have some
limitations.
Jacek Iwanski.
