V&N English Hungarian Dictionary 1.0 - foreign language learning
Download: http://archive.info-mac.org/edu/lang/vn ... ict-10.hqx
'English Hungarian Dictionary 1.0' is a dictionary module for use with the
'Verbs & Nouns' and 'V&N Lookup' programs. You can download the latest
versions of 'Verbs & Nouns' and 'V&N Lookup' directly from the Info-Mac
archives (the Education/Language directory), or via links from this web
site site: .
This dictionary contains more than 26000 English words (plus a few
thousands derivative forms and short phrases). It is mostly based on the
'FreeDict' source. This dictionary can serve as a starting point to enlarge
and improve its contents.
The dictionary module itself is free, to use it you need the shareware
program 'Verbs & Nouns 2.6.2' or later (or 'V&N Lookup 1.4.7' or later)
which you can download from the same places as this module - the
unregistered versions of 'Verbs & Nouns' and 'V&N Lookup' have some
limitations.
Jacek Iwanski.
