"Verbs & Nouns" Sample Phrases 1.1 - language learning
Download: http://archive.info-mac.org/edu/lang/v- ... ses-11.hqx
V&N Sample Phrases' is a sample collection of sentences for use with
English Inflection dictionaries (created with the Verbs & Nouns
language-learning program). This package is an easy way to try out the
'Phrase Engine' feature in Verbs & Nouns. You can extend this module by
adding more text-files to it.
To try out the module you should:
1. Make sure that the program Verbs & Nouns version 2.5.4 or later is
installed on your Hard Disk.
2. Download any of the following Verbs & Nouns Inflection Dictionaries:
- English Verbs 2.1 (or later),
- English Nouns 2.1 (or later),
- English Adjectives 2.1 (or later).
You can download any of these direct from the Info-Mac archives (the
Education/Language directory), or via links from this web site site:
. If you are downloading
especially in order to try the Phrase Engine, we recommend "English Verbs".
If you already have other English Inflection Dictionaries you can use them
instead.
Jacek Iwanski.
