PrepTutor2.0-Japanese Version
Download: http://archive.info-mac.org/edu/lang/prep-tutor-20.hqx
Freeware
PrepTutor-Version2.0J
(1) PrepTutor is a flashcard-type learning machine which is especially
designed to help one expand one's English vocabulary. The package contains
both "OSX version" and "Classic OS version".
(2) It consists of "Machine", "Quiz", "List", "Info", and "Find".
(3) You will be compiling your own dictionary or information database as
you go along.
(4) Each entry can be check-marked in two different ways.
(5) It comes with 20-skin schemes. You can also apply an image of your own
choice to change the appearance.
(6) The list can be printed.
(7) Words can be randomly shuffled or displayed in alphabetical order.
(8) Redundant entries can be easily extracted and deleted at a stroke.
(9) Drag/Drop aware.
(10) Data can be readily imported and exported.
(11) Thanks to its inherent database power, data can be readily sorted,
extracted and found.
New Features:
(1) "Slide Show"
(2) "Test" mode
(3) Pronunciation support
(4) "Words to work on" mode
(5) "Import Data" button
(6) "Export Data" button
Author : Jiro Negishi
http://www.kamakuranet.ne.jp/tagoe/preptutor.html
