Download: http://archive.info-mac.org/edu/lang/it ... bs-128.hqx
The inflection of verbs is one of the difficult parts of learning Italian
since there are numerous inflection patterns. "Italian Verbs" is a
dictionary module that helps you to learn these patterns and refresh your
knowledge about the rules for the inflection of verbs. The dictionary
contains approximately 490 irregular verbs, and 560 regular ones.
To open this dictionary module you should use the application "Verbs &
Nouns" version 2.4.7 or higher. You can download the program "Verbs &
Nouns" from the same place as this dictionary. You can
visit: to get more information.
Jacek Iwanski.
