Flashcard Wizard - Advanced Flashcard Software
Download: http://archive.info-mac.org/edu/lang/fl ... rd-095.hqx
Flashcard Wizard (0.95) is a flashcard application with dozens of features,
most powerful of which are its "Interval Study" features. To help students
study for long term retention of information, Flashcard Wizard's Interval
Study features spreads review of information over longer periods of time.
Designed originally to assist in the study of Korean, Japanese, and Chinese,
Flashcard Wizard is fully compatible with non-Roman scripts any any of the
Macs Language Kits if installed.
The application is fully customizable to every user's study needs with
almost a dozen preference panels, import/export options, and over a hundred
preferences. Flaschard Wizard comes with with online and offline help
files, balloon help, and tooltips to help new users and those who wish to
master Flaschard Wizard's more advanced features.
A PowerPC with system 7.5 or greater is required. The program is $18
shareware. After July 1st users have 50 uses of the program at which time
Interval Study and User features will disable until registration.
Help files, awards, reviews, screenshots, and other information about
Flashcard Wizard can be found at:
http://www.foolsworkshop.com/fw.html
