Download: http://archive.info-mac.org/disk/x-overload-10.hqx
X Overload is an application that allows you to manage items in
Classic system folder and library folders in Mac OS X.
X Overload allows you to manage Apple Menu Items, Contextual Menu
Items, Control Panels, Control Strips Modules, Extensions, Fonts,
Startup Items, Internet Plug-ins located inside Classic system
folder. You can also search or browser the database for error code.As
for Mac OS X, X Overload allows you to manage Contextual Menu Items,
Fonts, Preference files, Preference Panes, Services, Screen Savers
located in the library folders in Mac OS X. You can also find out
detail information about Frameworks and Kernel Extensions.
Over the time, you will fi nd items such as Contextual Menu Items,
Services, Extensions, Preference Panes and so on installed by third
party software scatter in your Classic and OS X system folder. X
Overload provide a one-stop interface allowing you to manage those
items with detail information of more than 6100 items so that you can
activate and deactivate them easily to tailor your system to your
current requirement.
Requirement: Mac OS X 10.0 or higher .
X Overload can also be downloaded from http://www.xoverload.com
Thank you!
Teng Chou Ming
X Overload Development Team
