VolumeSync 1.2.3
VolumeSync 1.2.3
Download: http://archive.info-mac.org/disk/volume-sync-123.hqx
VolumeSync is a volume synchronization utility program, nothing more or
less. It makes the target volume an EXACT copy of the original volume. Of
course the target volume is examined so that only files/folders that have
changed is copied. You should be able to use VolumeSync on any volumes that
you can access directly from the Finder.
New in this version is a few bug fixes and minor new features.
Sincerely,
Tommy Widenflycht
