Verifile 1.3 FAT
Verifile 1.3 FAT
Download: http://archive.info-mac.org/disk/verifile-13.hqx
Price: Freeware
Source: ftp://ftp.alpcom.it/software/mac/LMontalcini
FAT VERSION - CONTAINS BOTH 680x0 AND NATIVE POWERPC CODE
Verifile is a small freeware utility that calculates a
checksum and a CRC32 on both the data and resource forks of any
file that's dropped on it. This is useful if you want to compare
two files that are not on the same machine without having to
copy them over a network or modem connection. If the hexadecimal
numbers displayed by Verifile match, chances are that the two
files are equal; Verifile automatically compares these numbers
for the last two files that were checked and tells you if they
match or not. Verifile also displays the elapsed time to measure
processor and disk performance. The PowerPC code runs a lot
faster than the 68K code if the file to verify is on a RAM disk,
while the speed improvement is smaller on slower media.
New in 1.3:
- Verifile now automatically checks if the two last files
matched. Very smart indeed...
