Verifile 1.3J FAT (Japanese version)
Download: http://archive.info-mac.org/disk/verifile-13-jp.hqx
Verifile 1.3J is the Japanese version of Alessandro Levi Montalcini's original.
FAT VERSION - CONTAINS BOTH 680x0 AND NATIVE POWERPC CODE
* Verifile is a small freeware utility that calculates a checksum and a
CRC32 on both the data and resource forks of any file that's dropped on it.
This is useful if you want to compare two files that are not on the same
machine without having to copy them over a network or modem connection. If
the hexadecimal numbers displayed by Verifile match, chances are that the
two files are equal; Verifile automatically compares these numbers
for the last two files that were checked and tells you if they match or not.
* Verifile also displays the elapsed time to measure processor and disk
performance. The PowerPC code runs a lot faster than the 68K code if the
file to verify is on a RAM disk, while the speed improvement is smaller on
slower media.
New in version 1.3:
- Verifile now automatically checks if the two last files matched. Very
smart indeed...
This is freeware. Have fun!
Haruka Ishi
Dec 12, 1996
