TechTool Lite 3.0.4
TechTool Lite 3.0.4
Download: http://archive.info-mac.org/disk/tech-tool-lite-304.hqx
Originally known as the "freeware" version of TechTool. TechTool is the
acclaimed utility that solves those incurable problems which elude other
utilities. With TechTool you can:
* Analyze your system and finder for damage.
* Alter file and folder information with File Lab.
* Zap the entire PRAM chip.
* Delete the desktop file, the better alternative to rebuilding.
* Clean your floppy drive (use with drive cleaning disk).
* View, print and save a multitude of information about your Mac.
What's new in this version:
* Added support up to Mac OS 9.2.2 for Summer 2002 machines.
