Download: http://archive.info-mac.org/disk/tape-112.hqx
Tape 1.1.2 - Mac OS 9 Packge Creation Tool. Tape quickly and easily
creates Mac OS 9 "packages" which are simply special folders reformatted
to be treated as a single file under Mac OS 9.
Tape can convert folders into packages with optional pre-flighting which
checks for mistakes or potential problems with the target folder before
processing.
The included BoxCutter CMM operates independently of Tape to remove the
package setting for any folder on any PowerPC-based Mac running Mac OS 8
or newer.
Tape requires a PowerPC-based Mac running Mac OS 8.5 or newer. Tape will
