Synk is a backup and synchronization program. It was written using
Project Builder and requires Mac OS X 10.1 or greater.
As of version 4.0.1, Synk and its source code have been placed into the
public domain. Please make use of this code and release improvements in
any way you see fit. Derivative software will be owned by you. No
credit is required or even desired by the original author of Synk.
The author hopes that this source code will be useful to the Macintosh
community and will be employed in the spirit with which it is given.
