SwitchBack Classic 3.6J - Japanese Version
Download: http://archive.info-mac.org/disk/switch ... -36-jp.hqx
This is the Japanese version of the SwitchBack for Mac OS 8 & 9 package.
"Synchronize your files with ease and confidence."
SwitchBack is a file synchronization and backup utility.
SwitchBack makes it easy and safe to synchronize two disks, so that both
contain your most recently updated documents. Simply choose two folders
to compare, and SwitchBack does the rest, quickly and painlessly.
The two folders can reside on the same or different disks, or on two
computers connected by a network, or even over the Internet (such as an iDisk).
You can ask SwitchBack to tell you in detail what it is doing, or let it go to work,
only advising you when there's a problem.
Changes in this version:
*Many performence improvements under OS X
*Fixed errors with locked files and bundles under OS X
*Moving obsolete files to the trash works correctly under OS X
*Copy Folder Attributes once again optional in OS X
*New icons courtesy of Mike Berg
*Remains in the background during scheduled synchronizations
*Commencing a backup will wake a desktop computer from 'light' sleep
*A newly scheduled document is automatically enabled when first set up
*Added Show Activity Log to the File menu
*No longer flashes a notification after a successful synchronization
*A 'reopen' appleevent opens a new window regardless of user start up preference
