Suffit 1.0
Suffit 1.0
Download: http://archive.info-mac.org/disk/suffit-10.hqx
Suffit is a DOS/Windows file suffix manager for Macintosh.
It simply adds suffix to the file names based on the Mac Creator/Type, so,
you don1t have to put the suffix manually and to look at the file to check
if it1s in EPS or TIFF to add the right suffix. This is a time-saving
feature for everyone exchanging files between Mac and PC.
Manuals in english and italian are included
Program is freeware
