Description
Stella's Mover can help people moving from a Macintosh to a PC by renaming files
so that they can be copied to a PC and used easily. Some characters that are
allowed on the Macintosh cannot be used on a Windows 95 computer and often cause
problems when copied to a PC. Also, Windows computers do not support a resource
fork, which means that files need to have appropriate extensions in order to be
used. Stella's mover will add these extensions. This new version adds a log window
and more help options. Stella's Mover has a registration fee of $15.
