SpaceMaker Demo
SpaceMaker Demo
Download: http://archive.info-mac.org/disk/spacemaker-demo.hqx
SpaceMaker* Demo
This application is a demonstration version of SpaceMaker*. SpaceMaker* reclaims
unused disk space by converting Mac OS Standard format disks to Mac OS Extended
format. This demonstration copy lets you calculate exactly how much disk space
you will save by converting your disk.
SpaceMaker* converts your disks to Mac OS Extended format without requiring a
full backup of your hard disk before converting. SpaceMaker* is easy-to-use,
safe and reliable.
Minimum Requirements =====================
SpaceMaker* requires a PowerPC Macintosh running System 7.6 or higher and a
minimum of 5.7 MB of free memory. Disks converted to Mac OS Extended format with
SpaceMaker* can only be used on computers running Mac OS 8.1 or higher.
For More Information
