SmartSaver 3.4 (PPC native, MacOSX compatible):
SmartSaver helps you to back up changed and added files in your file system.
You have to specify source and destination locations and choose the
appropriate settings. Then you can make SmartSaver trace the source and
destination, and copy items on the source that are new or have been
modified, to the destination.
It can relocate files on a destination directory and thus group them by
project or category, based on the filename.
