ShrinkWrap 3.5.1 Updater
Download: http://archive.info-mac.org/disk/shrink ... te-351.hqx
Welcome to ShrinkWrap 3.5.1
Aladdin Systems provides you the complete solution for your disk image
needs with ShrinkWrap 3.5.1.
This release is a free upgrade for registered users of ShrinkWrap 3.5
and fixes a few issues that were found after we released version 3.5.
Bug fixes in 3.5.1
* Now creates StuffIt v5.5 archives.
* Fixed a bug where a user would crash if they chose the destination panel
in the Preferences option and then after choosing a destination went back
to the preferences and chose another panel.
* ShrinkWrap images (SMI's) now mount with color icons.
* Dropdown menus now update correctly due.
* Users now get significantly smaller images when using the "Don't copy
unused blocks" preference and StuffIt Compression when using HFS+ volumes.
