AMICO 2.1.1J - Japanese Version
Download: http://archive.info-mac.org/app/amico-211-jp.hqx
This is the Japanese version of the AMICO package.
AMICO 2.1.1J (An apple menu utility)
AMICO is a utility that helps you change the order of the items that
appear in the apple menu. It also lets you insert divider lines between
these items.
For more information read the "Read Me" file.
To ensure that AMICO will function properly under Mac OS 8 and up,
you need to check the "Always snap to grid" checkbox in the "View Options..."
dialog box of the Apple Menu Items folder and possibly do a "Clean Up"
for that folder as well.
