Download: http://archive.info-mac.org/disk/search ... ue-201.hqx
There are a myriad ways to recover files from a hard drive, but
conventional wisdom says that once unsaved data - existing only in ghostly
RAM - is lost, there's no way to EVER recover that data. Well, now there is
a way, because Search & Rescue does just that.
Hard drive recovery often costs over $1000, and involves days (or weeks) of
waiting. Unsaved text lost in RAM can be equally distressing but Search &
Rescue salvages your hard work within seconds for only $15!
Welcome to Search & Rescue, an application which gives you the ability to
quickly and easily recover text (which would otherwise be lost forever)
straight from your Mac's memory! You simply enter a word or two of text
from the lost material, click the button, and Search and Rescue will scour
through the dim recesses of your computer's memory until it comes up with
the goods...
Requirements:
Search & Rescue requires at least a 68k Macintosh running System 7.1
Changes in this version:
- Introduction of Search & Rescue Panic Key and RAM Image files.
- Search windows are now resizable.
- Search results logically ordered.
- Support for Navigation Services.
- More substantial manual.
- Generally nicer.
- Balloon help added.
- Fixed a bug which caused crashes on G4 machines, Search & Rescue should
now be stable on all Macs.
