ResHunterDemoPPC1.0.sit
Download: http://archive.info-mac.org/disk/reshun ... ppc-10.hqx
ResHunter is an advanced, but easy to use, search application.
ResHunter provides fast search capabilities with many different search
criteria, such as:
Volume/Folder Creator File type File name/substring
Fork type (resource fork, data fork or both) Resource name Resource type
Resource ID Hex- or ASCII-strings
ResHunter Manual
Foreword:
Our goal has been to make ResHunter as self-explanatory as possible.
ResHunter functions much like any other file search program, which means
that the search will be faster and more restricted the more search
criteria the user specifies.
Requirements:
PowerPC
8 Mb of RAM
Apple System 7.1 or later
